Normal Topic Speed of adding graph elements and layout (Read 4303 times)
thejimster
Sep 23rd, 2015 at 8:40am
I'm try to work out what my expectations should be for speed of operation of the diagram component.
Base on forum help I am doing the following to construct my graph:
Add all containers/nodes
Add all links
Layout all containers
Layout diagram
Route all links
I'm using a LayeredLayout (because I think this best fits the data) with the following properties:
LayeredLayout layout = new LayeredLayout();
layout.Orientation = MindFusion.Diagramming.Wpf.Layout.Orientation.Vertical;
layout.Anchoring = Anchoring.Keep;
layout.LinkType = LayeredLayoutLinkType.Cascading;
layout.StableSort = true;
layout.LayerDistance = 50;
layout.NodeDistance = 50;
layout.IgnoreNodeSize = false;
layout.EnableParallelism = true;
I've used a stopwatch to time the various phases, which are as follows:
==== Adding [555] Nodes: 00:00:00.2420000
==== Adding [785] Connections: 00:00:02.5310000
==== Layout Containers: 00:00:01.2920000
==== Layout Main: 00:00:11.9470000
==== Reroute Connections: 00:00:00.2870000
==== Total: 00:00:16.3050000
So, total time is about 16 secs, with the worst offenders being adding connections, and main diagram layout.
Is there anything I can do to speed this up?
I can code fragments if that would help pinpoint performance issues.
Jim.
Re: Speed of adding graph elements and layout
Reply #1 - Sep 23rd, 2015 at 9:44am
To improve speed of populating the diagram, use BeginInit/EndInit methods and disable ValidityChecks:
http://mindfusion.eu/Forum/YaBB.pl?num=1268995278/1#1
Also check if you aren't using some of the properties mentioned here:
http://mindfusion.eu/Forum/YaBB.pl?num=1358507496
For better LayeredLayout performance, try calling it with EnforceLinkFlow property enabled. Try also disabling the GrowToFit property and calling diagram.ResizeToTitItems only after all Arrange calls; this will avoid some iterations over all diagram elements and calculating union of their bounding rectangles done by each Arrange call for GrowToFit.
thejimster
Reply #2 - Sep 23rd, 2015 at 10:44am
Thanks Stoyan.
I have made the changes to use BeginInit/EndInit and turned off validity checking.  Unfortunately, this has made no noticeable difference to speed of adding diagram elements.
Changing GrowToFit has also made no noticeable difference.
Turning on EnforceLinkFlow causes an ArgumentOutOfRange exception during the layout phase:
>      mscorlib.dll!System.Collections.CollectionBase.System.Collections.IList.get_Item
(int index) Line 106      C#
     MindFusion.Diagramming.Wpf.dll!MindFusion.Diagramming.Wpf.PointCollection.this[int].get(int index)      Unknown
     MindFusion.Diagramming.Wpf.dll!MindFusion.Diagramming.Wpf.Layout.LayeredLayout.K
L(MindFusion.Diagramming.Wpf.Diagram Q, System.Collections.IEnumerable V)      Unknown
     MindFusion.Diagramming.Wpf.dll!MindFusion.Diagramming.Wpf.Layout.Layout.Arrange(
MindFusion.Diagramming.Wpf.Diagram diagram, MindFusion.Diagramming.Wpf.DiagramItemCollection items)      Unknown
MindFusion.Diagramming.Wpf.Diagram diagram)      Unknown
Jim.
Reply #3 - Sep 23rd, 2015 at 12:46pm
I was able to reproduce this in some code that processes repeating links between same nodes. It happens if AutoRoute is enabled, so for time being you could disable auto-routing before arranging:
foreach (var l in diagram.Links)
	l.AutoRoute = false;
// arrange
If it's not caused by AutoRoute, please attach saved diagram file from just before you run layout code.
Auto-routing could be slowing down node and link creation code too, you could defer enabling it for links until the diagram is fully arranged, and then enclose the assignment between LinkRouter.Supend and Resume calls to avoid re-routing the links:
diagram.LinkRouter.Suspend();
	l.AutoRoute = true;
diagram.LinkRouter.Resume(false);
thejimster
Reply #4 - Sep 23rd, 2015 at 1:43pm
Thanks Stoyan.
Turning off AutoRoute has enabled me to turn on EnforceLinkFlow.  With these two modifications in place I get results of:
==== Adding [551] Nodes: 00:00:00.2550000
==== Adding [781] Connections: 00:00:02.8520000
==== Layout Containers: 00:00:01.2230000
==== Layout Main: 00:00:00.5790000
==== Reroute Connections: 00:00:00.3050000
==== Total: 00:00:05.2400000
If I also Suspend/Resume LinkRouter around populating the graph:
==== Adding [551] Nodes: 00:00:00.3030000
==== Adding [781] Connections: 00:00:01.6480000
==== Layout Containers: 00:00:01.0870000
==== Layout Main: 00:00:00.5400000
==== Reroute Connections: 00:00:00.3470000
==== Total: 00:00:03.9550000
That's a pretty good improvement!
Is there any thing else that I can do to make further improvements?
Jim.
Reply #5 - Sep 23rd, 2015 at 1:55pm
You could assign smaller value to LayeredLayout.SwapPairsIterations property than default 5, but then you'll be getting more link crossings.
