Normal Topic How to get node ID (Read 2821 times)
RunMan
How to get node ID
Nov 11th, 2015 at 9:54am
we have created a diagram by using custom nodes (derived from ShapeNode). The diagram is saved to xml and i can see in the xml file under "Nodes" the single "Node" with attribute "Id".
But when i want to read out this id within the code it is null. Maybe it is not the same?
How can i get the unique ID of a diagram node?
RunMan
Re: How to get node ID
Reply #1 - Nov 11th, 2015 at 10:11am
The id attribute in XML files is generated only when saving files and used for deserialization purposes, to identify related items such as link's origin and destination nodes. If you need unique identifiers in runtime, you could assign them to the Id or Tag properties of items. E.g. you could keep an integer counter and assign its value to each new item added to the diagram if values should be unique for the diagram only, or Guid.NewGuid result if values should be unique across all your diagrams.
RunMan
Reply #2 - Nov 11th, 2015 at 10:47am
Hi Stoyan,
yes, that helps me.
We want to iterate through a logic diagram and therefore we have to know the connected nodes of a node. First we try to do this by above mentioned ID without success Smiley. I think it will be possible in the xml data via the links.
Now we try it in code by iterating through the incoming and outgoing links and their origins. Hope this will working.
Thank you
RunMan
Reply #3 - Nov 11th, 2015 at 11:57am
Right, you can access neighbor nodes via IncomingLinks and OutgoingLinks collections, for example using LINQ extensions:
var neighbors =
	node.IncomingLinks.Select(l => l.Origin).Concat(
	node.OutgoingLinks.Select(l => l.Destination));
foreach (var n in neighbors)
	n.Brush = Brushes.Red;
« Last Edit: Nov 11th, 2015 at 1:33pm by Stoyo »
