We have released version 2.5 of MindFusion.Diagramming for JavaScript. It contains the following new features:
Resize table columns and rowsColumns and rows of a TableNode can now be resized interactively if its AllowResizeColumns or AllowResizeRows properties are enabled. In order to resize, move the mouse pointer to the border line on column's right side or row's bottom side until it shows resize cursor and start dragging. The control raises tableColumnResizing and tableRowResizing events to let you validate new size or prevent resizing some elements. The tableColumnResized and tableRowResized events are raised after the operation completes.
Shape librariesThe ShapeLibrary class lets you use custom geometric shapes created using MindFusion ShapeDesigner tool. Call its loadFromXml method to load a library XML file. getShapes returns an array of the loaded Shape objects. The ShapeLibraryLocation property of NodeListView creates a prototype ShapeNode object for each shape from the specified library.
Miscellaneous~ TextStroke and TextStrokeThickness properties of DiagramItem let you set color and thickness of text outlines.
~ Items can now be deleted using Backspace key when running on Mac.
~ Caption divider line in TableNode and ContainerNode is now rendered clipped when caption height is smaller than corner radius.
~ The TooltipDelay property specifies the delay in milliseconds before showing tooltips.
~ The Orientation property of NodeListView lets you set the view's orientation to Horizontal or Vertical.
~ MindFusion.Common.js contains code shared with other JavaScript libraries by MindFusion. It must be loaded before the MindFusion.Diagramming.js script.
clients area on our site.
https://mindfusion.eu/JsDiagramTrial.zip Enjoy!
