Normal Topic Retain the starting coordinate (Read 2245 times)
Shah
Mar 1st, 2016 at 4:31am
Hi again,
Have a new question here. While using Layered Layout, is it possible to retain the starting node coordinate? Currently when i'm using Layered Layout, it will arrange all the nodes but at the same time the original coordinate of current node also will be changed including the starting node.
Thanks and Regards,
Shah
Re: Retain the starting coordinate
Reply #1 - Mar 1st, 2016 at 9:18am
Hello Shah,
Assign the fixed node to LayeredLayout.Root and enable LayeredLayout.KeepRootPosition.
Shah
Reply #2 - Mar 2nd, 2016 at 2:31am
Thanks..it's working
Rgrds,
Shah
