Normal Topic Appointment Moving (Read 5663 times)
ColinA
Appointment Moving
Jun 24th, 2016 at 8:18am
Hi
what's the best way to know if the appointment had been moved when dragging, I am using the mouse up to know when I have let go, but this also fires when just clicking on and empty slot is there a way of knowing its a appointment that has been released. Also if the appointment has been changed not just clicking on it and not moving the appointment.
Regards
Colin
Re: Appointment Moving
Reply #1 - Jun 27th, 2016 at 6:24am
Try the Calendar.ItemModified event. It is raised when an appointment is moved with the mouse, after the mouse has been released.
ColinA
Reply #2 - Jun 27th, 2016 at 11:17am
Cheers Meppy
fractal07
Reply #3 - Mar 13th, 2017 at 5:48pm
Hi Meppy,
I post here but maybe I have to create a new subject?
My issue is almost the same, I'm working on the "Scheduling Drag & drop demo" delivered with install and, by default, appointments could not be moved.
Could you tell me how to allow appointments to be moved? It's probably simple but I'm new in this (amazing) component and there's so many properties!
Reply #4 - Mar 14th, 2017 at 9:00am
There seems to be a left-over method that cancels the built-in appointment interactions and starts a drag & drop when the mouse is pressed and moved over an appointment. To remedy this, remove the _schedule_MouseMove event handler.
