Normal Topic Diagramming for ASP.NET MVC, V2.7 (Read 3034 times)
Jun 27th, 2016 at 12:16pm
We have released version 2.7 of MindFusion.Diagramming for ASP.NET MVC. It adds the following new features:
Free-form nodes
A FreeFormNode collects all points from users' mouse or touch input and displays them as node's outline. To let users draw free-form nodes interactively, set Behavior to DrawFreeForms or LinkFreeForms. Use the Points property of FreeFormNode to get or set outline points programmatically. If the Closed property is set, the node is drawn as a closed shape and its interior filled, or otherwise the node is drawn as a poly-line. If the distance between first and last points drawn by user is shorter than AutoCloseDistance, the node's Closed property is automatically set to true. AutoCloseDistance default value is float.MaxValue, so free-form nodes are always closed.
Convert free-form drawings to ShapeNodes
Additional drawing modes, convenient for touch input, convert FreeFormNode objects drawn by user to ShapeNode objects with matching shapes. To enable them, set Behavior to DrawFreeShapes or LinkFreeShapes. The shapes against which the user's input is matched are set via diagram's FreeFormTargets property. By default it contains Rectangle, Decision and Ellipse shapes.
  • TypeScript definitions for the Diagramming API are now provided in jsdiag.d.ts file.
  • The MaxJsonLength and RecursionLimit static properties of DiagramView class let you configure the corresponding settings of internal JavaScriptSerializer instances.
  • PdfExporter now creates page hyperlinks if HyperLink is set to a value in "page://{number}" format, e.g. set "page://1" to open the second PDF page when the item is clicked.
  • VirtualScroll mode fixed for parent div size specified in percent units.
  • Fixed bug where the ExpandOnIncoming property specifying link direction for collapse/expand actions did not work correctly.
  • Removed several global JavaScript variables created inadvertently by the control.
https://www.mindfusion.eu/MvcDiagramTrial.zip
Updated assemblies and script files are also available as MindFusion.Diagramming.Mvc NuGet package.
