Normal Topic Importing complex visio stencils (Read 2806 times)
Cyrinael
Jul 25th, 2016 at 10:56am
currently I try to import complex visio shapes which consist of serveral sub-shapes. I use the import functionality from the VisioStencil tutorial. Nevertheless, the resulting shapes don't look nearly the same as in Visio. I saw that the shapes that are used in the tutorial (from Country.vsx) only consist of 1 shape(the whole image) and wanted to know if I have done anything wrong or the import only works with simple VisioShapes like the ones used in the VisioStencil-Project.
I have added pictures of the shapes as attachment.
Thank you,
Cyrinael
Re: Importing complex visio stencils
Reply #1 - Jul 27th, 2016 at 12:23pm
VisioNode draws all shapes from the master -
foreach (var shape in content.Master.Shapes)
    DrawShape(graphics, options, shape, bounds);
DrawShape also recursively draws embedded shapes. It might not be showing same results as in Visio if there are some special constants or variables used in the shape formulas - these aren't documented usually and we must implement by guess-work. Please attach the stencil file and our developer will check it.
Cyrinael
Reply #2 - Aug 3rd, 2016 at 8:34am
Hi Slavcho,
unfortunately we have 1000+ stencils, which contain a lot of formulas and calulations. We have decided to only show the Icon of the Stencil, instead of using the master's shapes.
Thank you,
Cyrinael
Reply #3 - Aug 3rd, 2016 at 10:04am
Send us a couple to inspect anyway? If you get them from same source, they could all contain some common feature we've omitted to implement.
Cyrinael
Reply #4 - Aug 3rd, 2016 at 12:02pm
Hi Slavcho,
is there a way to send the files via E-Mail?
Thank you,
Cyrinael
Reply #5 - Aug 3rd, 2016 at 12:28pm
Yes, please send them to support@mindfusion.eu email address.
