Normal Topic Derived TableNode classes and improperly drawn diagramLinks (Read 2910 times)
Alex Nicoll
Jul 26th, 2016 at 1:18pm
I use a custom class that inherits from the TableNode class, called the ExtendedTableNode class.  Before adding this new class to a diagram, I made sure to change the diagram link handling for TableNodes to link to tables, not rows.
When I draw my diagram, I add multiple ExtendedTableNodes, and then call the Diagram.Factory.CreateDiagramLink() function to create links between them.  If I do not cast the ExtendedTableNode to TableNode in the function call, the links are created between the top rows in the tables.  If I do cast the ExtendedTableNode to TableNode, the links are drawn between the tables, as desired.   So far so good.
However, when adding a link manually between two ExtendedTableNodes by using a mouse when the application runs, the link connects the top rows in the tables, rather than the tables.  The question is, is there a way to make the   diagram links connect the tables, rather than the rows?  I cannot find a function to override to provide proper casting, or I would do that.
Any ideas?
Online
Re: Derived TableNode classes and improperly drawn diagramLinks
Reply #1 - Jul 26th, 2016 at 1:30pm
Set the ConnectionStyle property of tables to TableConnectionStyle.Table and the link shouldn't let you connect individual rows.
Alex Nicoll
Reply #2 - Jul 26th, 2016 at 6:40pm
Slavcho -
Thank you very much for the reply.  Unfortunately, that was the first thing I did, and I am still seeing the behavior.
-Alex
Online
Reply #3 - Jul 26th, 2016 at 6:44pm
Have you set Diagram.TableConnectionStyle or TableNode.ConnectionStyle? The former is automatically assigned to the latter only for nodes created using the TableNode(Diagram) constructor.
Alex Nicoll
Reply #4 - Jul 27th, 2016 at 6:51pm
Slavcho -
Good point, I missed that one.  I changed the ConnectionStyle for the TableNode derivative class in the constructor, and that seems to have fixed the issue.
Thanks!
-Alex
