Normal Topic Access X and Y of the ShapeControlPoint (Read 2332 times)
Cyrinael
Aug 9th, 2016 at 1:34pm
is there a way to access the X and Y property of a ShapeControlPoint?
Best regards,
Cyrinael
Re: Access X and Y of the ShapeControlPoint
Reply #1 - Aug 10th, 2016 at 10:18am
These are not stored in ShapeControlPoint but calculated dynamically when needed by node from its current size and ShapeFormulaParam values. We'll add a public API to return them in next couple of days.
Cyrinael
Reply #2 - Aug 10th, 2016 at 11:00am
Hi Slavcho,
thank you for your effort.
Best regards,
Cyrinael
Reply #3 - Aug 12th, 2016 at 8:56am
Hi Cyrinael ,
The build below adds following  method to ShapeControlPoint -
https://mindfusion.eu/_beta/wpfdiag341.zip
public Point? LocationForNode(ShapeNode node, bool local)
Set local to true to get coordinates relative to the node, or false to get coordinates in the diagram. The result might be null if the node is not of same Shape as the one containing the control point.
Cyrinael
Reply #4 - Aug 12th, 2016 at 12:02pm
Hi Slavcho,
that works perfectly!
Best regards,
Cyrinael
