Normal Topic Anchoring problem (Read 4263 times)
Gravity
Anchoring problem
Oct 5th, 2016 at 1:34pm
I have a problem with loading from xml custom nodes, for test purposes i use flowshart.xml which is in samples folder, what i do i just rename classes there into my own thats it.
Well it loads and displays correctly, except diagramlinks and node are not attached, if i try to move it, diagram links stays were whey were... i have custom nodes only with properties, nothing else...
What could be wrong?
Re: Anchoring problem
Reply #1 - Oct 5th, 2016 at 2:39pm
If using custom link types, you must also add origin and destination parameters to the constructor and pass them to base one. The control instantiates links like this when loading from XML or JSON -
var link = new type(this.diagram, origin, destination);
The help file lists them as optional, but seems they are required for serialization.
Gravity
Reply #2 - Oct 6th, 2016 at 3:21pm
Slavcho wrote on Oct 5th, 2016 at 2:39pm:
yes i am using custom links, i have defined that in .net classes and i have rewritten js prototype like this:
Code (Javascript)
myDiagramLink = function (parent, origin, destination) {
    myDiagramLink.initializeBase(this, [parent, [origin, [destination]]]);
i have no special logic of drawing, just couple of properties on the DiagramingLink, but right now not using them and they are empty tag's in XML
What else could it be?
Reply #3 - Oct 6th, 2016 at 4:30pm
You should pass the arguments as a flat array, same way you would call Function.apply -
...initializeBase(this, [parent, origin, destination]);
Gravity
Reply #4 - Oct 7th, 2016 at 9:27am
Slavcho wrote on Oct 6th, 2016 at 4:30pm:
Oh, that worked! I was following documentation in jsDiagramming component DiagraminkLink constructor is described like this:
Code (Javascript)
function DiagramLink ([parent, [origin, [destination]]])
Reply #5 - Oct 7th, 2016 at 12:31pm
I think that's more of a notation about arguments being optional, rather that an array of arrays. Although we established they are not that optional when you need to implement serialization in the custom class Undecided
