Normal Topic Problem of Maven dependencies (Read 2209 times)
fatine
Dec 29th, 2016 at 4:02pm
I'm trying to load a Java Swing project as a Maven application in Eclipse, but i got the following errors:
1) Missing artifact edu.umass.cs:mallet:jar:0.4   Maven Dependency Problem
2) Missing artifact net.sourceforge.alpie:datagenerator:jar:0.1.1   Maven Dependency Problem
3) Project build error: Non-resolvable parent POM for net.sourceforge.alpie:datagenerator:0.2-SNAPSHOT: Failure to find net.sourceforge.alpie:parent:pom:0.1.1 in http://alpie.sourceforge.net/maven2/ was cached in the local repository, resolution will not be reattempted until the update interval of alpie-repo.releases has elapsed or updates are forced and 'parent.relativePath' points at wrong local POM      Maven pom Loading Problem.
4) The container 'Maven Dependencies' references non existing library 'C:\Users\Fatine\.m2\repository\edu\umass\cs\mallet\0.4\mallet-0.4.jar'    Build Path Problem.
Here is the link to the project: https://sourceforge.net/projects/alpie/
Could you help me fix these errors please?
