Normal Topic Need to get parent container object? (Read 1744 times)
Ankur shah
Mar 23rd, 2017 at 10:24am
I am creating container using createContainerNode method and attaching the shape node to it. My problem is that we have created the factory for these type of custom container so i need to know which shape node is clicked for whcih container so that i can collapse the container using setFolded (true).
Can it be feaseable ?
Re: Need to get parent container object?
Reply #1 - Mar 23rd, 2017 at 11:15am
If you mean the helper nodes attached to caption-bar of container from last thread using attachTo method, you should be able to get it by calling attachedNode.getMasterNode().
If you were adding a node to a container using ContainerNode.add method, then you'd call childNode.getContainer() - such nodes would hide when the container folds.
Ankur shah
Reply #2 - Mar 23rd, 2017 at 12:34pm
Smiley Solved
