is it possible to allow to create these node that aligning with Straight Line or U Line. ?
1. Straight Line
2. U line
Here the scenarios I'm trying to populate these node
1. Top of the Straight Line, Create Nodes After each Inch, Left to Right
2. Bottom of the Straight Line, Create Nodes After each Inch, Left to Right
3. Inside the U shape, create nodes,
from bottom line of the U shape, bottom line center to left, then bottom line center to right,
then left line of the U shape, bottom to up
then right line of the U shape, bottom to up
4. Outside the U shape, create nodes,
