MindFusion
  HomeHelpSearchLoginRegister
Pages: 1 2  Send Topic Print
How to add multiple text to a node?
Read 1568 times
Gu Wenwei   Offline
May 5th, 2017 at 3:48am
Slavcho   Offline
Gender: male
Re: How to add multiple text to a node?
Reply #1 - May 5th, 2017 at 9:29am
Use either TableNode with multiple cells or CompositeNode with multiple TextComponents. If you prefer ShapeNodes, you could set CustomDraw = Additional and draw more text by calling e.Graphics.DrawString from DrawNode event handler.
Gu Wenwei   Offline
Reply #2 - Oct 12th, 2017 at 6:30am
Excuse me, can you give me an example?
Slavcho   Offline
Gender: male
Reply #3 - Oct 12th, 2017 at 6:47am
For TableNodes check ClassDiagram or InteractiveTable examples. For CompositeNodes check the Scripting and Demo (EmployeeNode.cs) examples. For custom drawing example see e.g. https://mindfusion.eu/Forum/YaBB.pl?num=1355256377/3#3 , you will need to set node's CustomDraw property to get the event raised.
Gu Wenwei   Offline
Reply #4 - Oct 15th, 2017 at 10:20am
Can Override Shape to Add multiple text?
Slavcho   Offline
Gender: male
Reply #5 - Oct 16th, 2017 at 6:33am
You can create a custom node class and override its DrawLocal method -
Code:
class ShapeNodeEx : ShapeNode
	public string MoreText { get; set; }
	public override void DrawLocal(IGraphics graphics, RenderOptions options)
		base.DrawLocal(graphics, options);
		graphics.DrawString(MoreText, EffectiveFont, Brushes.Black, 1, 1);
Alternatively keep an array of strings as value of Tag property, and draw them in a loop from DrawNode event handler with CusotmDraw property set.
Gu Wenwei   Offline
Reply #6 - Dec 20th, 2017 at 2:09pm
how to Create a ShapeNodeEx?
Cannot that:
ShapeNodeEx b = diagram.Factory.CreateShapeNode(pt, new SizeF(20, 20));
Slavcho   Offline
Gender: male
Reply #7 - Dec 20th, 2017 at 4:01pm
Code:
var b = new ShapeNodeEx();
b.Bounds = new RectangleF(...);
diagram.Nodes.Add(b);
Gu Wenwei   Offline
Reply #8 - Mar 10th, 2018 at 1:04pm
How do I put the position of SHAPE in the center?
Gu Wenwei   Offline
Reply #9 - Mar 11th, 2018 at 3:25am
b.TextFormat.Alignment = StringAlignment.Center;
b.TextFormat.LineAlignment = StringAlignment.Center;
Slavcho   Offline
Gender: male
Reply #10 - Mar 12th, 2018 at 9:44am
Use the DrawString overload that takes a Rectangle and StringFormat arguments, passing node.GetLocalBounds() and your StringFormat as values.
Gu Wenwei   Offline
Reply #11 - Mar 13th, 2018 at 3:51am
thx
Gu Wenwei   Offline
Reply #12 - Apr 22nd, 2018 at 2:30pm
how to convert diagram.Nodes to ShapeNodeEx?
Slavcho   Offline
Gender: male
Reply #13 - Apr 23rd, 2018 at 6:37am
Nodes could contain instances of multiple types. You can use the
as
operator to determine type while looping over the collection -
Code:
foreach (var node in diagram.Nodes)
    var exNode = node as ShapeNodeEx;
    if (exNode != null)
or get filtered collection using Linq's OfType extension -
Code:
var exNodes = diagram.Nodes.OfType<ShapeNodeEx>();
Gu Wenwei   Offline
Reply #14 - Apr 23rd, 2018 at 1:28pm
        private void LoadFCSfile(string fn)
            diagramView.LoadFromFile(fn);
            bool btag = false, bp = false;
            foreach (DiagramNode node in diagram.Nodes)
                if (node is ControlNode)
                    btag = true;
                else
                    ShapeNodeEx b = node as ShapeNodeEx;
                    if (b.Shape.ToString() == "MyBlock")  //b is null, ShapeNode b, OK
                        bp = true;
b is null
when ShapeNodeEx is ShapeNode, OK
