Normal Topic Support for Virtualization of a diagram with containerDiagrams. (Read 4143 times)
Z
May 8th, 2017 at 12:46pm
Diagraming -> WPF.
As a dev I would like to be able to use VirtulaizationDiagram where such diagram contains different types (Nodes and ContainerNodes). Virtualization should take into account Nodes placed inside ContainerNode.
More details here:
http://mindfusion.eu/Forum/YaBB.pl?num=1493301652
Re: Support for Virtualization of a diagram with containerDiagrams.
Reply #1 - Jun 14th, 2017 at 11:52am
Please find initial support for containers implemented here -
https://mindfusion.eu/_beta/virtualize_containers.zip
VirtualizingDiagram looks for a Container property in data items, referring to another data item. If the container item has been realized as a ContainerNode, the child node will be placed inside it. If it has been realized as another node type, the child node will be attached using AttachTo method. Alternative to using data_item.Container property is implementing a ResolveContainer callback -
public delegate object ResolveContainer(object dataItem);
