I loaded following panels
using following commands
<mfc:PropertyGrid x:Name="diagramPropertyGrid" SectionCornerRadius="0" Header="Diagram Properties" DescriptionVisibility="Collapsed" Padding="0" Margin="4,10,10,0" SectionMargin="0,0,0,0" PropertyDisplayType="DeclaredOnly" ShowReadOnlyProperties="False" Grid.Column="0" Grid.ColumnSpan="6" />
<mfc:PropertyGrid x:Name="wpfPropertyGrid" SectionCornerRadius="0" Header="Selected Object Properties" Grid.Row="1" Padding="0" Margin="4,10,10,6" SectionMargin="0,0,0,0" PropertyDisplayType="DeclaredOnly" ShowReadOnlyProperties="False" Grid.Column="0" Grid.ColumnSpan="6" />
here mfc is "xmlns:mfc="clr-namespace:MindFusion.UI.Wpf;assembly=MindFusion.Common.Wpf""
but here "diagram properties" not loading.
once I select object on canvas its not loading to "Selected Object Properties" panel
what code behind changes should I do to get these diagram properties and selected object properties
