Normal Topic The overview object can't display well on Chrome (Read 5140 times)
Toyogray
Jun 9th, 2017 at 7:43am
I am developing my JsDiagram application with Firefox, so far, it works well.
But I found the overview object can't display well on Chrome. I tried the Flowcharter example, the appearance is not good (the text size on overview is even the same on diagram).
Current situation: please check the attachment: OnChrome.PNG
Is there any way can make the overview area like the attachment expected.PNG?
Re: The overview object can't display well on Chrome
Reply #1 - Jun 9th, 2017 at 9:11am
What version of the library, Chrome and operating system are you using? It looks fine with my v3 diagram, latest Chrome Version 59.0.3071.86 (Official Build) (64-bit), Windows 7.
Toyogray
Reply #2 - Jun 12th, 2017 at 2:30am
My environment:
Chrome: Version  59.0.3071.86 (64 bit)
Operating system: Windows 7 64bit (Traditional Chinese version)
I have reset my Chrome and try to apply JsDiagram V3, the result is still bad!
After more and more try, I found the cause: It's caused by Chrome's language setting!
After making Chrome's language to "English Version", the appearance became okay just like your post.
Will you fix this issue?
Reply #3 - Jun 12th, 2017 at 7:04am
Apparently DrawingContext2D.font from Canvas API does not work with fonts smaller than 4-5 pixels on Chinese Chrome - it enforces a minimum size. The control removes scale transforms and multiplies the font size instead when drawing text, because text with scale transform was rendered ugly in older versions of Chrome. We'll check if they look better now and will start rendering with scale transforms again which should fix that.
Reply #4 - Jun 12th, 2017 at 1:51pm
Using scale transform and drawing text looks even worse on Chinese Chrome unfortunately. You can try it by calling this for a simple Canvas element -
context.scale(4, 4);
context.font = "4px sans-serif";
context.fillText("This is test 1",10, 10);
The Chinese version (left side of attached image) shows it several times larger than the English one, at least when we try English texts.
So we'll keep using our current method of drawing texts. Only option we can think of is to disable texts in Overview altogether - we'll try to add that for upcoming small release.
Reply #5 - Jun 13th, 2017 at 9:19am
Try this version -
Set overview.minVisibleFontSize = 3 or 4 and it should stop rendering text.
Toyogray
Reply #6 - Jun 21st, 2017 at 2:32am
Hi Slavcho,
Thanks for the new version, it worked well in my project.
Just for your reference, the NodeListView has the same problem (custom nodes on NodeListView), I met it and modified my nodes' drawing function to avoid the bad effect. Hope it will be fixed.
Sincerely,
Toyogray
Reply #7 - Jun 21st, 2017 at 7:53am
Hi Toyogray,
Same minVisibleFontSize flag should work for the NodeListView too, it's defined in our base Canvas class from which all other controls derive.
Toyogray
Reply #8 - Jun 26th, 2017 at 2:10am
Hi Slavcho,
Before my last post, I ever tried to set minVisibleFontSize flag on NodeListView and it didn't work.
FYR & Regards,
Toyogray
Reply #9 - Jun 26th, 2017 at 12:45pm
Right, NodeListView overrides some paint methods and wasn't processing minVisibleFontSize there; it should work with this build -
https://mindfusion.eu/_temp/jsdiag_minfont.zip
