MindFusion
  Now beta testing first versions of our Scheduler and Virtual Keyboard components for HTML & JavaScript.
  HomeHelpSearchLoginRegister
MindFusion XML Viewer 4.1: Problem with memory
Read 471 times
Mirsait   Offline
Jun 21st, 2017 at 1:30pm
After opening in turn 3 -4 large files (~ 250 MB each) memory is not freed.
Actions: (open the file -> close the file ) * 3
System: W8.1 x64
Program: MindFusion XML Viewer 4.1
Meppy   Offline
Gender: male
Re: MindFusion XML Viewer 4.1: Problem with memory
Reply #1 - Jun 27th, 2017 at 8:25am
The application is built using .NET and relies on a Garbage Collector to free unused memory. Occasionally the used memory should be freed. Do you run out of memory if you continue to open and close large files?
Slavcho   Offline
Gender: male
Reply #2 - Jul 19th, 2017 at 1:59pm
New version here should fix the leak -
https://mindfusion.eu/XMLViewer.zip
