Normal Topic Line thickness and scatter type in linechart (Read 2161 times)
abhi dhotre
Jul 18th, 2017 at 7:45pm
I want to set thickness of the line in line chart. I tried UniformSeriesThickness and SeriesStrokeThickness but it doesn't seem to work. I also want to set the scatter type for the chart and size of the scatter.
Abhi D  Smiley
Re: Line thickness and scatter type in linechart
Reply #1 - Jul 19th, 2017 at 3:01pm
You can see a larger thickness set in LineChart sample project like this -
lineChart.Plot.SeriesStyle = new MixedSeriesStyle()
    UniformStrokeThickness = 5
Note that if you have assigned a SeriesStyle to either separate series or the Plot, this will have higher priority than values you assign to the chart.Theme.
It seems we don't have direct properties to customize the scatter shape and size in line charts. You can specify them like this instead -
lineChart.ShowScatter = true;
var scatterRenderer = lineChart.Plot.
    SeriesRenderers.OfType<ScatterRenderer>().FirstOrDefault();
if (scatterRenderer != null)
    scatterRenderer.Shape = ScatterType.Diamond;
    scatterRenderer.ShapeSize = 20;
