Normal Topic How to add license (Read 4387 times)
Shafi
How to add license
Aug 17th, 2017 at 12:35pm
I am looking at the Mindfusion Diagramming API. The documentation states that I should either set the LicenseKey property in Mindfusion.Diagramming or call the method MindFusion.Licensing.LicenseManager.AddLicense to set the license key.
But both these APIs are missing in the typescript definitions. Can you please tell me what is the correct way to add license using typescript definitions?
Re: How to add license
Reply #1 - Aug 17th, 2017 at 1:02pm
That sounds like our .NET diagramming API. You can find JavaScript version here -
https://www.mindfusion.eu/onlinehelp/jsdiagram/index.htm?Licensing_2.htm
Copy your key into diagram_lic.txt file and deploy it in same folder as the html, or in a different location specified using diagram.setLicenseLocation(url). Alternatively set the key directly by calling diagram.setLicenseKey(key).
Shafi
Reply #2 - Aug 18th, 2017 at 7:33am
The methods setLicenseLocation and setLicenseKey are missing in the type definitions. Could you please provide me updated type definitions?
Reply #3 - Aug 18th, 2017 at 7:53am
I can see them in the d.ts file defined in base Canvas class which the Diagram inherits, see attached screenshot.
Shafi
Reply #4 - Aug 18th, 2017 at 8:04am
You are right. They are available on Canvas in the d.ts file. But I cannot access them via diagram.
See image.
Reply #5 - Aug 18th, 2017 at 8:35am
It could be your IDE does not show auto-complete info from base classes. Visual Studio shows the methods for me. Try typing the method name without completion and it should compile anyway.
