Normal Topic Horizontal bar chart not supported on Logarithmic scale (Read 3326 times)
abhi dhotre
Aug 30th, 2017 at 5:30pm
Bar chart works while using a logarithmic scale but when I change the orientation of the chart to horizontal it throws an exception. Same is the case when I set bar chart layout to stack instead of side by side.
Abhi D
Re: Horizontal bar chart not supported on Logarithmic scale
Reply #1 - Aug 31st, 2017 at 5:49am
The following changes in LogChart example will display X as logarithmic scale -
public Form1()
originalData.YAxisLabelsDataField = "Labels";
barChart.XAxis.CustomFormat = new LogCustomFormatter();
barChart.XAxis.Interval = 1;
barChart.XAxis.MaxValue = 8;
barChart.ShowYCoordinates = false;
barChart.HorizontalBars = true;
DataTable CreateSampleData()
    row[0] = values[i];
    row[2] = labels[i];
    row[1] = ++i;
class LogSeriesAdapter : Series
public double GetValue(int index, int dimension)
   if (dimension == 0)
    return Math.Log10(series.GetValue(index, dimension));
   return series.GetValue(index, dimension);
abhi dhotre
Reply #2 - Sep 6th, 2017 at 6:30pm
This code works only if I use side by side bar layout. I want to have stack bar layout, it gives me overflow error if I use stack bar layout
Reply #3 - Sep 6th, 2017 at 7:46pm
The LogChart example does not throw exception if I switch to stacked bars. What call stack does the debugger show when it happens for you?
