Normal Topic How to increase width of diagramview (Read 2472 times)
ashar11
Sep 25th, 2017 at 7:09am
    I am facing an issue while increasing the width of diagramview, the maximum width it allows me is,
    diagramView.Size = new System.Drawing.Size(793, 680);
   By increasing width more than 793 it removes the horizontal bar, why its not allowing more than (793) thanks
Ashar
Re: How to increase width of diagramview
Reply #1 - Sep 25th, 2017 at 7:15am
The scroll range depends on diagram.Bounds size, make it larger than the view and scrollbars will appear again. Call DiagramView.ClientToDoc method to convert from DiagramView's pixel size to diagram MeasureUnit (default millimeter) if necessary.
ashar11
Reply #2 - Sep 25th, 2017 at 8:33am
     I have tried by setting diagram.Bounds by setting it more than diagramview size after converting it to mm by using diagramView.ClientDoc ,its still not showing me horizontal bar can you please confirm me what i am doing wrong. Thanks
            // diagramView
            diagramView.Size = new System.Drawing.Size(796, 680);
            // diagram
            diagram.Bounds = diagramView.ClientToDoc(diagramView.ClientRectangle);
Reply #3 - Sep 25th, 2017 at 8:48am
That fits exactly the diagram's scroll range inside current viewport and does not need scrollbars. You should treat it as lower limit and set larger values than it if you want to ensure visible scrollbars. Alternatively set diagram's AutoResize property and scrollbars will appear eventually when the user draws nodes outside of current diagram's boundaries.
ashar11
Reply #4 - Sep 25th, 2017 at 10:16am
Thanks now its working.
