MindFusion
  HomeHelpSearchLoginRegister
How to get the node's data in the savedfile?
Read 461 times
Gu Wenwei   Offline
Oct 12th, 2017 at 6:27am
How do I not open the file to get the node's data in the savedfile? Embarrassed
Slavcho   Offline
Gender: male
Re: How to get the node's data in the savedfile?
Reply #1 - Oct 12th, 2017 at 6:36am
If you save using SaveToXml method you could parse the XML files yourself if you want to avoid loading them into the diagram for some reason (implementing a search function?).
If you are trying to avoid loading into currently visible diagram instance, note that you can create and load an off-screen Diagram without showing it inside a DiagramView. Then look for node data in the off-screen Diagram using its .NET API, while only your main diagram shows on screen.
Gu Wenwei   Offline
Reply #2 - Oct 12th, 2017 at 1:11pm
thx, i select 2
