Normal Topic Diagram.DiagramItem.Parent randomly null (Read 1376 times)
tjugg
Oct 20th, 2017 at 9:27am
Sometimes, when trying to fetch the parent of a DiagramItem,
it randomly (works 99% of the time) is null. What could be causing this / is this a known issue?
t
Re: Diagram.DiagramItem.Parent randomly null
Reply #1 - Oct 20th, 2017 at 9:47am
Something like this could happen if you use groups, if you attach a subordinate node to master node but do not add the subordinate to diagram.Items, and then access through master.SubordinateGroup.Nodes[XX].Parent. If not using groups, maybe check if there isn't a reference to deleted item stored somewhere.
