Hot Topic (More than 10 Replies) Center handler hittest & TouchThreshold (Read 8712 times)
Kyle Chen
Oct 23rd, 2017 at 4:45pm
Can you tell me what the center handler is for? Usually I'm using handles.Move as base then add side and corner handles based on object type. Here's a problem, in 6.5 and later, there's a TouchThreshold property added for easy access of handlers on touch screen. If I set it to a big value like 8 or 10, the left sides handlers on left/right work great but hard for the top/bottom one because the hittest range for center handler will be enlarged too which affect the top/bottom range.
Can you look into that? Maybe we can disable the hittest range change of center point.
Kyle Chen
Re: Center handler hittest & TouchThreshold
Reply #1 - Oct 23rd, 2017 at 7:10pm
You can draw links from there usually if that's the EasyMove style. If you are disallowing links via some property or event handlers, I guess we could ignore the center handle when hit-testing for that style. Or try using the SquareHandles2 style - it gives you large area for moving the node too.
Kyle Chen
Reply #2 - Oct 25th, 2017 at 7:49pm
Hi Slavcho,
No, I don't need any link on any object. So is there any way to ignore the center handle when hit-testing in v6.5.1? Or are you talking about next release? Grin
Kyle
Slavcho wrote on Oct 23rd, 2017 at 7:10pm:
Reply #3 - Oct 26th, 2017 at 6:09am
Hi Kyle,
At this time you could set HandlesStyle to Custom and subscribe to DrawAdjustmentHandles and HitTestAdjustmentHandles events. From the draw event call InternalUtils.DrawSelHandles method to get standard handle rendering, and from hit-test one set HitResult as you see fit.
Kyle Chen
Reply #4 - Nov 13th, 2017 at 9:47pm
Hi Slavcho,
I'd rather wait until this is done by you guys. Already too many custom stuff in my code. Do you have plan to add code to hittest for case without any link allowed?
Kyle
Slavcho wrote on Oct 26th, 2017 at 6:09am:
Hi Kyle,
Reply #5 - Nov 16th, 2017 at 10:39pm
Hi Kyle,
In what way are you preventing links, via Behavior property or some event handling?
Kyle Chen
Reply #6 - Nov 17th, 2017 at 5:15pm
Hi Slavcho,
In my application there's no links between nodes. I think you can hittest to side handlers first if there's no link in/out of a node. Does this make sense?
Kyle
Slavcho wrote on Nov 16th, 2017 at 10:39pm:
Hi Kyle,
Reply #7 - Nov 17th, 2017 at 5:19pm
Are you using a Behavior value that does not allow links at all?
Reply #8 - Nov 20th, 2017 at 7:32pm
Check if this build works better for you -
https://mindfusion.eu/_beta/fcnet_handles.zip
It now selects the handle whose center point is closer to the touch point, rather than first one found to contain it.
Kyle Chen
Reply #9 - Dec 8th, 2017 at 9:32pm
Hi Slavcho,
This works great. Thank you very much! Grin
When will be a formal release with this?
Kyle
Slavcho wrote on Nov 20th, 2017 at 7:32pm:
Reply #10 - Dec 11th, 2017 at 8:40am
Hi Kyle,
We should have a small release in January. Build from above has changes only in hit-testing code so it should be stable too.
Kyle Chen
Reply #11 - Dec 11th, 2017 at 4:01pm
OK, cool. I'll use that version. Thanks for your help, Slavcho.
Slavcho wrote on Dec 11th, 2017 at 8:40am:
Hi Kyle,
Kyle Chen
Reply #12 - Feb 1st, 2018 at 4:06pm
Hi Slavcho,
I'm using the test version you sent to me above(I unzipped it to a stand-alone folder and modify the references to point to them in my project). However recently when I try to open an existing form, it shows the existingError.png. I then copy the test version files to replace existing C:\Program Files (x86)\MindFusion\MindFusion.Diagramming for WinForms\CLR4 (.NET 4.0)\, it still the same issue.
Even I reverse the references to old regular version. It still shows the same error.
Then I create a new project and in the main form I add a diagramView, it shows the error as DiagramViewError.png.
What can cause this? and how to fix it?
Kyle
Reply #13 - Feb 2nd, 2018 at 9:50am
Hi Kyle,
Could be Visual Studio trying to use different assemblies for the design.dll it loads for design-time support in form editor. Try running this tool to clear the VS assembly cache -
https://mindfusion.eu/_temp/cleanvs.zip
Kyle Chen
Reply #14 - Feb 2nd, 2018 at 3:20pm
Hi Slavcho,
I run cleanvs.exe but it still gives the same error... Embarrassed
I then reset the references to the formal release of 6.5.1.401, it works immediately.
I guess the beta version you sent to me is not a complete set.
I checked, the following files are missing(especially the design file):
MindFusion.Licensing.dll
Design\MindFusion.Diagramming.WinForms.Controls.Design.dll
Design\MindFusion.Diagramming.WinForms.Design.dll
Another issue, did you change the PublicKeyToken to "dd7449df9ffcc455"?
Kyle
