Poll
Poll closed Question: how to use custom font in mindfusion org chart ?
bars   pie
*** This poll has now closed ***
in sample.css filr
  1 (100.0%)
in jquery-ui.min.css file
  0 (0.0%)
in jquery-ui.structure.min.css file
  0 (0.0%)
or in jquery-ui.theme.min.css file
  0 (0.0%)
Total votes: 1
« Created by: Surhar on: Nov 24th, 2017 at 8:33am »
Very Hot Topic (More than 25 Replies) custom fonts in org chart (Read 17137 times)
Surhar
i want to create family tree website using mindfusion orgchart structure.. but i want to use custom fonts in it. i used
@font-face {
font-family: 'Kimberley Bl';
src: url('C:/users/admin/fonts/terafont-chandan.ttf') format('truetype');
and then use it in the *.js with the diagram objects:
this.getCell(1, 1).setFont(
new Font("Kimberley Bl", 3.5, true /*bold*/, false /*italic*/));
this.getCell(2, 1).setFont(
but i cant understand in which css file i should write css code for custom font... Please Reply
Lyubo
MindFusion team
Re: custom fonts in org chart
Reply #1 - Nov 24th, 2017 at 9:10am
The problem in your case is caused by the fact that the font can't be accessed by using an absolute path URI like 'C:/users/admin/fonts/terafont-chandan.ttf'. You should put the font in a path your webserver can access and use e relative path URI. For example, if your directory structure is like this:
.\index.html
.\css\style.css
.\fonts\terafont-chandan.ttf
you should reference the font in the css file like this (note the relative path):
Code (CSS)
@font-face {
  src: url('../fonts/terafont-chandan.ttf') format('truetype');
Lyubo
Surhar
Reply #2 - Nov 24th, 2017 at 10:48am
i need some more help i used i used 'this.getCell(0, 0).setTextAlignment(Alignment.Center);' for set node text center of the node but whats happen right side margin automatically incressed and some cherectors hided in left side text crosed border of node and result is some text cut out... for exaple if text is 'AKSHAY'A and K is hided loft side and only 'SHAY' displaying and still not in center...please reply early
Lyubo
MindFusion team
Reply #3 - Nov 24th, 2017 at 11:21am
Can you post a screenshot here that shows the problem?
Lyubo
Surhar
Reply #4 - Nov 24th, 2017 at 12:16pm
i attached image i used indian language 'Gujarati' Font when i write code for set text center 'this.getCell(0, 0).setTextAlignment(Alignment.Center);' some text cut from left side i want to text should be wraped when word contain to many charecters please reply..
Surhar
Reply #5 - Nov 24th, 2017 at 12:28pm
here is project files you can find the problem.. check attached files
Lyubo
MindFusion team
Reply #6 - Nov 24th, 2017 at 1:13pm
The OrgChartEditor sample uses custom nodes, which inherit from the TableNode class, which represents a table-like grid with a header.
The text is clipped, because there are two more columns inside the node and they occupy the space to the right. If you don't need the grid capabilities of TableNode, you may achieve better results by using ShapeNode. Alternatively, you can redefine the tables to have only one column, or make use of the columnSpan property.
In your project, in the OrgChartNode constructor, initialize the table with only one column:
Code (Javascript)
// set up table cells
this.redimTable(1, 4);
or you can use the columnCount property (you will need v3.2):
Code (Javascript)
this.setColumnCount(1);
Lyubo
Surhar
Re: text alignment in orgchart js
Reply #7 - Nov 24th, 2017 at 1:22pm
thack you for reply.. i wrote 'this.redimTable(1, 1);' the result is all nodes are hided..may be some other problem with my code..please check my orgchart.js file and give your suggestion..
Lyubo
MindFusion team
Reply #8 - Nov 24th, 2017 at 1:42pm
This sample is made with a (3,4), that's why you may be getting errors, which prevent the nodes to draw correctly.
In your example I changed: this.redimTable(3, 4); to this.redimTable(1, 4); and commented out the call to the configureCellsmethod (as it assumes (3,4) grid): //this.configureCells(); and the text is now centered in the nodes.
I would again suggest you look into using ShapeNodes, as it appears that you don't need the functionality that TableNodes provide.
Lyubo
Surhar
Reply #9 - Nov 24th, 2017 at 5:32pm
Thank you so much, its working but in long words some word still cut off from both side you can check by using my custom-font download from bellow or you can check by increase font size..if shape node is batter option please explain me how can i use it...
Surhar
Reply #10 - Nov 25th, 2017 at 6:50am
Hey Lyudo Please reply i need it so much..
Surhar
Reply #11 - Nov 26th, 2017 at 10:49am
The text is in center now but but texts are cut offs in long word names please help me I am eating for your reply
Surhar
Reply #12 - Nov 26th, 2017 at 10:50am
Surhar
Reply #13 - Nov 26th, 2017 at 4:01pm
Please reply if you have any idea or if you have no idea Pls suggest me how can I idea for this is there are any other forum for find solutions or any other person in this forum Pls help me...
Lyubo
MindFusion team
Reply #14 - Nov 27th, 2017 at 8:20am
As I said earlier, the OrgChart sample assumes table nodes with (3,4) cells grid and will be difficult to customize if you don't need the table features.
To use ShapeNodes, call the diagram Factory's createShapeNode method, set the text, then call risizeToFitText. Add the links between nodes and then arrange the diagram with the TreeLayout.
Information and tutorials on how to use JsDiagram can be found in the chm file supplied with the package and online at https://www.mindfusion.eu/onlinehelp/jsdiagram/index.htm - namely in the Programming Interface Overview and Tutorials topics.
A simple example on how to add shape nodes to the diagram and arrange them using the tree layout:
Code (Javascript)
var Alignment = MindFusion.Diagramming.Alignment;
var FitSize = MindFusion.Diagramming.FitSize;
var Rect = MindFusion.Drawing.Rect;
var shapeNode1 = diagram.getFactory().createShapeNode(new Rect(0, 0, 10, 5));
shapeNode1.setText("Hello from ShapeNode 1!");
shapeNode1.resizeToFitText(FitSize.Ratio);
var shapeNode2 = diagram.getFactory().createShapeNode(new Rect(0, 0, 10, 5));
shapeNode2.setText("Hello from ShapeNode 2!");
shapeNode2.resizeToFitText(FitSize.Ratio);
var shapeNode3 = diagram.getFactory().createShapeNode(new Rect(0, 0, 10, 5));
shapeNode3.setText("Hello from ShapeNode 3!");
shapeNode3.resizeToFitText(FitSize.Ratio);
diagram.getFactory().createDiagramLink(shapeNode1, shapeNode2);
diagram.getFactory().createDiagramLink(shapeNode1, shapeNode3);
var layout = new MindFusion.Graphs.TreeLayout();
layout.direction = MindFusion.Graphs.LayoutDirection.TopToBottom;
layout.linkType = MindFusion.Graphs.TreeLayoutLinkType.Cascading;
diagram.arrange(layout);
Lyubo
