MindFusion
  HomeHelpSearchLoginRegister
Getting shapeToolbar with having custom images
Read 464 times
ashar11   Offline
Gender: male
Nov 29th, 2017 at 7:52am
    After shifting the platform from winform to wpf I am having difficulty in using shapetoolbar cause it has changed to DraggedShape as i got to know after looking around but still not having a clue how to implement it in c# dynamically.
Meppy   Offline
Gender: male
Re: Getting shapeToolbar with having custom images
Reply #1 - Nov 29th, 2017 at 1:15pm
There is no ShapeToolBar in the WPF version of the diagram and the DraggedShape class is not really used. It is recommended that you use the ShapeListBox control instead. However, if you really need a toolbar, you can implement one manually, by using a ListBox with a custom ItemsPanel and ItemTemplate. You can use a true ToolBar control, but its panel is harder to replace so it will not be easy to make the shapes wrap.
The following sample demonstrates how to implement a ShapeToolBar using a ListBox:
http://mindfusion.eu/_samples/_diagram_ShapeToolbar.zip
I hope this helps.
ashar11   Offline
Gender: male
Reply #2 - Nov 29th, 2017 at 2:01pm
Yes this is what I need .Thanks
Lyubo   Online
Gender: male
MindFusion team
Reply #3 - Dec 6th, 2017 at 10:15am
You will need to set an outline to your custom shape, otherwise the hittesing code is not detecting the node below the mouse cursor. To hide the default outline and fill of the node, you can set the Stroke and Brush properties to a transparent brush, or set the ShapeNode.Transparent property to true:
Code:
var customShape = new Shape(new[]
   new LineTemplate(0, 0, 0, 100),
	new LineTemplate(0, 100, 100, 100),
	new LineTemplate(100, 100, 100, 0),
	new LineTemplate(100, 0, 0, 0)
  }, 0, "Smiley");
Code:
private void diagram_NodeCreated(object sender, NodeEventArgs e)
  DiagramNode Nd = e.Node;
  if ((Nd as ShapeNode).Shape.Id == "Smiley")
   SolidColorBrush transparentBrush = new SolidColorBrush(Colors.Transparent);
   (Nd as ShapeNode).Stroke = transparentBrush;
   (Nd as ShapeNode).Brush = transparentBrush;
// or
//   (Nd as ShapeNode).Transparent = true;
  SolidColorBrush defAnch = new SolidColorBrush(Colors.Red);
  Nd.AnchorPattern = new AnchorPattern(new AnchorPoint[]
   new AnchorPoint(10, 25, true, true, MarkStyle.Rectangle, defAnch),
	new AnchorPoint(10, 50, true, true, MarkStyle.Rectangle, defAnch),
	new AnchorPoint(10, 75, true, true, MarkStyle.Rectangle, defAnch)
Lyubo
ashar11   Offline
Gender: male
Reply #4 - Dec 6th, 2017 at 12:34pm
