Normal Topic FlowChartX V4.9.4 released! (Read 2057 times)
Dec 4th, 2017 at 11:34am
We have released version 4.9.4 of FlowChartX. It contains the following new features:
Flip shapes
The shape of bsShape boxes can be flipped horizontally or vertically. Enable the AllowFlip property and the shape flips when an edge is dragged over its opposite edge. You can get or set current flip state using FlipX and FlipY properties.
Arrow improvements
  • ArrowsSplittable now works for Bezier links too. Users can insert a new Bezier segment by dragging any point (other than a control point) of a selected link. Adjacent segments can be merged back into a single one by dragging a tangent control point (square adjustment handle) onto a pass-through control point (round adjustment handle).
  • IntermArrowHead shapes are now rendered at correct position for Spline links.
  • KeepGroupLayout property now available in all graph layout classes (previously only in TreeLayout). If KeepGroupLayout is enabled, a group of nodes is treated as single vertex of the graph being arranged, and initial relative positions of group's nodes are preserved.
  • bhPan Behavior value lets you pan the view without holding down modifier keys.
  • The installer now automatically registers the 64-bit version of the control as a COM library.
Installer for the latest version can be downloaded here, or from the clients area on our site.
https://www.mindfusion.eu/FCXdemoPro.zip
