Normal Topic 3) Non-sizeable node: (Read 2258 times)
Shafi
Dec 27th, 2017 at 6:53am
We need to create node in such way that, User should not able to update it’s size (it is selectable\movable but it is not resizable).
Re: 3) Non-sizeable node:
Reply #1 - Dec 27th, 2017 at 8:09am
try with node.setEnabledHandles(AdjustmentHandles.Move);
Shafi
Reply #2 - Dec 29th, 2017 at 8:55pm
Tried this but didn't achieved what I want.
I single AdjustmentHandles value of ON/OFF resize handle, Right now there are following types.
           ResizeTopLeft = 1,
           /** The top-right handle is enabled and can be used to resize the node. */
           ResizeTopRight = 2,
           /** The bottom-right handle is enabled and can be used to resize the node. */
           ResizeBottomRight = 4,
           /** The bottom-left handle is enabled and can be used to resize the node. */
           ResizeBottomLeft = 8,
           /** The top-center handle is enabled and can be used to resize the node vertically. */
           ResizeTopCenter = 16,
           /** The middle-right handle is enabled and can be used to resize the node horizontally. */
           ResizeMiddleRight = 32,
           /** The bottom-center handle is enabled and can be used to resize the node vertically. */
           ResizeBottomCenter = 64,
           /** The middle-left handle is enabled and can be used to resize the node horizontally. */
           ResizeMiddleLeft = 128,
can't set set all at type i.e.not ON/OFF resize node in all direction.
Reply #3 - Jan 2nd, 2018 at 9:37am
It also contains a Move = 256 value which you can set to make nodes movable but not resizable. Otherwise these are bitmask values and you should be able to combine them using the bitwise or | operator if you need something more elaborate.
Shafi
Reply #4 - Jan 3rd, 2018 at 1:21pm
Thanks now it working Smiley
