MindFusion
  HomeHelpSearchLoginRegister
Can I rename MindFusion.xxxx.dll to the other filename?
Read 419 times
Gu Wenwei   Offline
Jan 4th, 2018 at 5:15am
Can I rename MindFusion.xxxx.dll to the other filename, but use it normally?
Slavcho   Offline
Gender: male
Re: Can I rename MindFusion.xxxx.dll to the other filename?
Reply #1 - Jan 4th, 2018 at 6:24am
You cannot, it will break the references to shared assemblies. You could use a 'merge assemblies into executable' option provided by .NET obfuscator softwares to merge dll files into your exe if you want to hide them.
Gu Wenwei   Offline
Reply #2 - Jan 4th, 2018 at 12:05pm
after "ILMerge.exe" merge, cannot run.
