Normal Topic Diagramming for Windows Forms, V6.5.2 (Read 2979 times)
Mar 3rd, 2018 at 8:06am
We have released version 6.5.2 of FlowChart.NET. It contains the following new features and improvements:
LayeredLayout improvements
  • The KeepLinkShapes property of LayeredLayout lets you preserve initial Shape value of links when LinkType is set to Cascading. The orthogonal path applied by latter property is approximated using respective link shape.
  • Fix for wrong link positions when the diagram contains folded containers.
  • Fix for unnecessarily large distance between subsequent layers after a long node appears in a layer.
PathFinder improvements
  • Speed of FindAllCycles and EnumAllCycles methods improved.
  • FindAllCycles and EnumAllCycles no longer report mirrored versions of cycles in undirected mode.
  • Improved precision when hit testing adjustment handles from touch event handlers.
  • Fix for incorrectly exported Procedure shape by ExcelExporter.
Updated assemblies are also available as MindFusion.Diagramming NuGet package.
