Normal Topic Diagram.NodeClicked not raised when mouse is moving (Read 3959 times)
tjugg
Mar 22nd, 2018 at 12:48pm
When I move the mouse cursor on the diagram and try to click, it seems that the Diagram.NodeClicked event is not raised at all. It works fine when the mouse is somewhat still. Any ideas what could be causing this?
// t
Re: Diagram.NodeClicked not raised when mouse is moving
Reply #1 - Mar 23rd, 2018 at 6:16am
Indeed, the control raises click events only if the mouse hasn't moved more than couple of pixels. That's on purpose, otherwise it starts drawing new items or selection lasso and doesn't consider it a click anymore. If you still want to detect it, you could call GetNodeAt from diagram.MouseDown event handler.
