MindFusion
  HomeHelpSearchLoginRegister
How to print all node and maximize node?
Read 645 times
Gu Wenwei   Offline
Mar 27th, 2018 at 3:38am
How to print all node and maximize node, automatic set page to landscape or portrait ?
Slavcho   Offline
Gender: male
Re: How to print all node and maximize node?
Reply #1 - Mar 27th, 2018 at 8:33am
I'm not sure what you mean by maximize node. You could check the result of diagram.GetContentBounds and specify yourself landscape or portrait mode depending on the rectangle's width to height ratio.
Gu Wenwei   Offline
Reply #2 - Apr 10th, 2018 at 1:00pm
This is now generated.
Gu Wenwei   Offline
Reply #3 - Apr 10th, 2018 at 1:01pm
I hope so.
Slavcho   Offline
Gender: male
Reply #4 - Apr 11th, 2018 at 9:02am
If you are asking how to print in landscape mode, check https://mindfusion.eu/Forum/YaBB.pl?num=1377873427/1#1
You can find some scaling options in DiagramView.PrintOptions object.
« Last Edit: Apr 11th, 2018 at 10:17am by Slavcho »
