Normal Topic Scheduling for JavaScript, V1.1 Released (Read 3687 times)
Iva_P
May 11th, 2018 at 11:08am
We have released a new version of the scheduling library or JavaScript. It contains the following new features and improvements:
New Properties
New ItemSettings.titleFormat and ItemSettings.tooltipFormat properties to better control the appearance of schedule Items.
VSDoc Intellisense
The MindFusion.Scheduling-vsdoc.js file that is included in the distribution archive now lists all properties of a class, not only the class and its methods. All members are listed with their brief API description.
React Samples
All samples of the library can now be run using �create-react-app�. A file with detailed instruction is included in the downloadable archive.
API Documentation Includes Class Inheritance
The library documentation - both online and offline - has been extended to include for each JavaScript class it's base class, if such exists. For base classes, it lists all classes that inherit from them.
The trial version is available for download from https://mindfusion.eu/JsScheduler.zip
Learn more about Scheduling for JavaScript at https://mindfusion.eu/javascript-scheduler.html or browse the online samples at https://mindfusion.eu/products/javascript/scheduling/samples
An online demo is available at https://mindfusion.co/demos/?sample=702
The npm references of the library have already been updated with the new build. Visit https://www.npmjs.com/package/scheduler-library or run "npm install scheduler-library"
If you have questions or require technical support with Js Scheduler, please write at the forum: https://mindfusion.eu/Forum/YaBB.pl?board=calendar_js
« Last Edit: Nov 30th, 2020 at 3:06pm by Forum Admin »
