Normal Topic Diagram.IsLicensed takes a long time to execute (Read 2440 times)
milosa
Jul 5th, 2018 at 3:29pm
I have the large diagram, 210 ContainerNodes, each having ~10 ShapeNodes and ~10 links.
When I add the new node on the diagram it is very slow for me so I was doing the profiling of that execution and the output from the profiler I send as an attachment.
It shows that 80% of the time is spent in the ArrangeOverride method where 74% is spent in the IsLicensed getter.
Do you have an idea how to resolve this?
Best regards,
Milos
Re: Diagram.IsLicensed takes a long time to execute
Reply #1 - Jul 5th, 2018 at 6:10pm
This build caches some results and should avoid the attribute calls shown in the chart -
https://mindfusion.eu/_temp/wpfdiag_attr.zip
milosa
Reply #2 - Jul 6th, 2018 at 1:50pm
Hello Slavcho,
This actually seem to bring a drastic improvement for the performance in the big diagrams.
When can we get the proper release (with a nuget package) including the fix?
Best regards,
Milos
Reply #3 - Jul 9th, 2018 at 11:51am
We won't be releasing soon but will try to publish this build as a nuget update.
milosa
Reply #4 - Jul 11th, 2018 at 6:25am
So if you can write here when the new nuget package is available it would be great.
Thanks!
Reply #5 - Jul 13th, 2018 at 8:22am
