MindFusion
  HomeHelpSearchLoginRegister
Use Diagramming in Typescript/Angular
Read 520 times
Davaaron   Offline
Jul 12th, 2018 at 5:32pm
is there anyone who managed to import the 'diagram-library' npm package into an Angular 2+ project?
I added diagram-library to package.json and saved the file which caused an automatic restorage of my npm packages in my node_modules folder.
The diagram-library folder contains some Javascript files (Common, Diagramming) and a typed file (t.ds).
I'd like to take advantage of that typings, that's why I am not including the JavaScript files by the HTML <script> tags.
What I did was the following:
Code (Javascript):
import { MindFusion } from 'diagram-library';
import Diagram = MindFusion.Diagramming.Diagram;
import DiagramLink = MindFusion.Diagramming.DiagramLink;
import ShapeNode = MindFusion.Diagramming.ShapeNode;
import Rect = MindFusion.Drawing.Rect;
import LayeredLayout = MindFusion.Graphs.LayeredLayout;
The first line is throwing an error, saying: Quote:
The file ".../jsdiag.t.ds" is not a module
I think the problem is that you are not exporting the declared namespace nor any classes?
But I don't know, as I'm pretty new to Angular and Typescript.
How can I solve the issue without losing the advantage of type safety on compile time and word suggestions?
Thanks in advance  Smiley
Lyubo   Offline
Gender: male
MindFusion team
Re: Use Diagramming in Typescript/Angular
Reply #1 - Jul 13th, 2018 at 12:43pm
Adding a reference path to the typed diagramming file should be enough to resolve the types in the library:
Code (Java):
/// <reference path="node_modules/diagram-library/jsdiag.d.ts" />
Also, make sure that the MindFusion.Common.js and MindFusion.Diagramming.js scripts are referenced and loaded by the browser. If you're not using jquery, you should also set the MindFusionImpl StandAlone setting:
Code (HTML):
<script type="text/javascript">MindFusionImpl = "StandAlone"</script>
<script src="node_modules/diagram-library/MindFusion.Common.js"></script>
<script src="node_modules/diagram-library/MindFusion.Diagramming.js"></script>
Lyubo
Davaaron   Offline
Reply #2 - Jul 13th, 2018 at 3:55pm
thanks for your quick response. It seems to work now. Every npm package that I have installed yet, could be imported easily by the code shown in the starting post.
AK   Offline
Reply #3 - Oct 23rd, 2018 at 4:31am
I am new in mind fusion, i want to use in Angular 2 , but i am getting below error.
my code here:
import AnchorPattern = MindFusion.Diagramming.AnchorPattern;
import AnchorPoint = MindFusion.Diagramming.AnchorPoint;
import DiagramNode = MindFusion.Diagramming.DiagramNode;
import MarkStyle = MindFusion.Diagramming.MarkStyle;
import Style = MindFusion.Diagramming.Style;
import Theme = MindFusion.Diagramming.Theme;
import HandlesStyle = MindFusion.Diagramming.HandlesStyle;
import Events = MindFusion.Diagramming.Events;
import Shape = MindFusion.Diagramming.Shape;
Lyubo   Offline
Gender: male
MindFusion team
Reply #4 - Oct 23rd, 2018 at 8:24am
Did you try the solution, already provided in the thread above?
Lyubo
Lyubo   Offline
Gender: male
MindFusion team
Reply #5 - Oct 24th, 2018 at 8:34am
Attached to this post is a minimal sample Angular application, that demonstrates how to add the diagram component.
Lyubo
MinApp.zip (95 KB | 38 )
