Normal Topic Delete Node (Read 1390 times)
Kuzya
Delete Node
Aug 8th, 2018 at 3:33pm
Deleting nodes does not always work.
I use
diagram.setDelKeyAction(DelKeyAction.DeleteSelectedItems);
Do I need anything else?
Kuzya
Re: Delete Node
Reply #1 - Aug 9th, 2018 at 9:15am
Maybe the diagram does not have the keyboard focus, try first clicking on it to make it acquire focus. Also check if you aren't stopping deletion from nodeDeleting event handler.
Kuzya
Re: Delete Node
Reply #2 - Aug 9th, 2018 at 12:46pm
In "KeyboardInputDispatcher." the focus element of the diagram is checked if the object on which the keyboard event is executed. The first time you open the dialog this is also true and the deletion works correctly. As soon as you open a dialog the second time in which the diagram is created, the comparison seems to be no longer true.
What could be the connection?
Kuzya
Re: Delete Node
Reply #3 - Aug 10th, 2018 at 9:30am
By opening a dialog do you mean a new browser window or some DOM element in same window? If it's in same window, try calling document.body.removeChild(diagram.focusDiv) when closing these dialogs.
