Normal Topic Serialisation of dockControl/dockItem layout (Read 2147 times)
MarkAGr
New to it all, really
frustrating at the moment.
Aug 21st, 2018 at 11:33pm
I've tried setting up a set of dockItem-s in a dockControl then saving using savetoxml ... fine, I get an xml file
But nothing happens when I try to reload the configuration with loadfromxml.
Can you point me to an example of this working please.
8^)
Mark
Lyubo
MindFusion team
Re: Serialisation of dockControl/dockItem layout
Reply #1 - Aug 23rd, 2018 at 7:29am
You will need to handle the DockControl.ItemLoading event, and reload the item's content from there. A working example of this can be downloaded from this link: https://mindfusion.eu/winforms-ui-controls-samples.html - the Dock Control sample.
void dockControl1_ItemLoading(object sender, ItemEventArgs e)
    if (e.Item.Content == null)
        if (e.Item.Id == "TabbedDocument")
            e.Item.Content = GetContent("Tabbed Document");
        // Rest of the items omitted for clarity
private Control GetContent(string contentType)
    Control control = null;
    if (contentType == "Tabbed Document")
        Label label = new Label();
        label.Padding = new Padding(10);
        label.BorderStyle = BorderStyle.None;
        label.Margin = new Padding(0);
        label.Text = "...";
        label.BackColor = Color.White;
        control = label;
    return control;
Lyubo
MarkAGr
Reply #2 - Aug 24th, 2018 at 8:20am
Great!
Thank You.
