Hot Topic (More than 10 Replies) change color link and property (Read 12403 times)
08804139
Oct 15th, 2018 at 11:36am
hello,
I'm using ASP webforms and mindfusion.
how can I write two text in the same link ?
how can I change the link color using a color palette?
how can I remove link arrows and use a single line?
as present in the attachment
thanks
Re: change color link and property
Reply #1 - Oct 15th, 2018 at 4:22pm
Call the link's AddLabel method (or addLabel in JS code).
Set link's Pen property (setPen / setStroke in JS).
Set link's HeadShape property to Arrowheads.None / null.
Reply #2 - Nov 6th, 2018 at 9:42pm
I want when I click on the link in the top part a text box opens and even in the bottom part of the link
so two text box in the link.
Reply #3 - Nov 7th, 2018 at 12:09pm
You could call link.addLabel from linkClicked handler and then LinkLabel.setLinkLengthPosition(...) to move the label towards the start or end of the link.
Reply #4 - Nov 9th, 2018 at 4:12pm
thank you for your help. Smiley
but when I define two labels I initialize side javascript code and when I click to change. the original text remains below the new text.
so there is a problem of modification textarea zone size.
Undecided
Code :
  function onLinkCreated(sender, args) {
        var link = args.getLink();
        link.setHeadShape("");
        link.setBaseShape("");
        link.addLabel("T1").setLinkLengthPosition(0.1);
        link.addLabel("T1").setLinkLengthPosition(0.9);
Reply #5 - Nov 12th, 2018 at 7:38am
Maybe there's duplicated T1 label overlapping the edited one? How many elements can you see in link.labels array, e.g. from a breakpoint in linkClicked handler?
Reply #6 - Nov 13th, 2018 at 10:58am
Hello
*the same problem at the label editing level the text box is very small, also if I delete the label it becomes inaccessible.
*the link changes behavior after save
how do I keep their behavior even after saving
attached pice present
1 before saving
2 after saved
I want always presented as 1
I use mindfusion ASP webforms
Thanks for your help
Reply #7 - Nov 13th, 2018 at 1:24pm
1. Handle the enterInplaceEditMode event to get a reference to the area element used as editor (args.control) and apply some minimum width / height to it.
2. What methods are you using to save and load?
Reply #8 - Nov 13th, 2018 at 3:56pm
thank you for your reply.
I used the following two methods:
protected void btnSave_Click(object sender, EventArgs e)
if (!String.IsNullOrEmpty(tbFileName.Text))
string localDir = MapPath(@"Files\");
System.Xml.XmlDocument doc = new System.Xml.XmlDocument();
canvasView.SaveToXml((localDir + tbFileName.Text);
protected void btnLoad_Click(object sender, EventArgs e)
if (!String.IsNullOrEmpty(listFileNames.SelectedValue))
canvasView.Diagram.LoadFromXml(localDir + listFileNames.SelectedValue,true);
Reply #9 - Nov 13th, 2018 at 4:55pm
Could you attach XML file for the above example?
Reply #10 - Nov 14th, 2018 at 7:23am
When I click on the button save the diagram gets refreshed and becomes like the picture 2 presented above.
Method Save :
canvasView.SaveToXml(localDir + tbFileName.Text);
Method Load:
attached XML file
Reply #11 - Nov 14th, 2018 at 12:21pm
It loaded as a straight line in my test. Check if you aren't calling link.route() or diagram.routeAllLinks() methods in some event handlers?
Reply #12 - Nov 14th, 2018 at 4:30pm
Thank you for your quick reply. Cheesy
now the save and loading is working properly.
so I changed the style of the text box
Just the problem of editing the label link.
if I delete the label I can not insert it anymore and change position.
I presented my problem in the video.
Reply #13 - Nov 14th, 2018 at 7:18pm
Right, the label isn't actually deleted but becomes hard to hit when its text is empty, and then the diagram starts editing the link.text property instead of a LinkLabel. You could extend the hit-testing method along these lines to always return one of the labels depending on distance from end points -
DiagramLink.prototype.getObjectToEdit = function (point, element)
	if (element && (mflayer.isInstanceOfType(mdiag.LinkLabel, element)))
		return element;
	var label = this.labelFromPoint(point);
	if (label != null)
		return label;
	// above is the standard hit-testing code;
	// revise this depending on number of labels:
	if (point.distance(this.getStartPoint()) < 20)
		return this.labels[0];
	if (point.distance(this.getEndPoint()) < 20)
		return this.labels[2];
	return this.labels[1];
	//return this;
Reply #14 - Dec 21st, 2018 at 10:11pm
Hello
can you give me more idea and clarify the previous point.
and how I can direct the text of the link on the left as indicated by the attachment.
thank you.
