Normal Topic Copy & Paste Multiple object (Read 2690 times)
Marco Pessina
Oct 31st, 2018 at 4:12pm
I'm using Diagram for asp.net mvc, and I've realized a copy paste pattern. Everything work correctly when I copy and paste only one item everything works fine.
If I select more items (nodes and links), the item are copied
in the diagram but I got an error in the console and my javascript execution breaks. The error I got is this:
VM4883:1 Uncaught TypeError: Cannot read property 'onLoad' of undefined
    at b.Diagram.pasteFromClipboard (eval at <anonymous> (eval at globalEval (jquery-2.1.3.js:328)), <anonymous>:1:132924)
Any suggestion?
Can you help me?
Thanks in advance.
Regards.
Marco Pessina
Re: Copy & Paste Multiple object
Reply #1 - Nov 1st, 2018 at 10:30am
We have reproduced with unconnectedLinks argument of paste method set to false. Set it to true for time being, or unselect links before copy if their nodes are not selected.
