Normal Topic Can't add typings file to Angular 7 project (Read 1259 times)
twojtylak
Jan 9th, 2019 at 6:07pm
I have an Angular 7 project where I am including the 'diagram-library' module in my component, but I am getting an error saying that 'jsdiag.d.ts' is not a module. I have Googled for answers and found a couple stating I should include
Code (Javascript)
/// <reference path="node_modules/diagram-library/jsdiag.d.ts" />
, but everywhere I've tried to put this doesn't seem to work.
For reference, here is my component:
Code (Javascript)
import {Component, OnInit} from '@angular/core';
import {MindFusion} from 'diagram-library';
@Component({
    selector: 'app-root',
    templateUrl: './app.component.html',
    styleUrls: ['./app.component.css']
export class AppComponent implements OnInit {
    constructor() {
    ngOnInit() {
Any suggestions?
Lyubo
MindFusion team
Re: Can't add typings file to Angular 7 project
Reply #1 - Jan 10th, 2019 at 8:07am
Are you using the latest version of diagram-library from npm - version 3.3.0? If yes, the following should be enough:
Code (Javascript)
import * as c from 'mindfusion-common';
import * as m from 'diagram-library';
import Diagram = m.Diagramming.Diagram;
If using an older version, you need to add that reference path in the typings.d.ts file in your src folder and manually reference the required scripts in the angular.json configuration file. That approach is shown in the \Angular\MinApp sample, included with the JsDiagram package.
Lyubo
twojtylak
Reply #2 - Jan 10th, 2019 at 3:10pm
Thank you so much! That worked! I didn't know I also needed to import 'mindfusion-common'.
