Very Hot Topic (More than 25 Replies) Export Diagram to Image (Read 15509 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Jan 18th, 2019 at 6:22am
     We can export the diagram to image in mindfusion silverlight diagram lite. May I know whether the same is possible in html/js?
Thanks & Regards,
Kannan
Re: Export Diagram to Image
Reply #1 - Jan 18th, 2019 at 9:31am
The HTML canvas element is already an image. You could encode it to some format by calling e.g. canvas.toDataURL("image/png"). Here's many examples using that method -
https://stackoverflow.com/questions/923885/capture-html-canvas-as-gif-jpg-png-pd
f
Kannan Thirumal
Senior Member
Reply #2 - Jan 30th, 2019 at 2:01pm
Hi Slavcho,
We have an silverlight application (which has diagram like process flow/fishbone etc) developed with mind fusion diagramlite. Now we are rewriting the same with html5, angular and typescript.
From the below link I understood mind fusion has diagram typescript support,
https://mindfusion.eu/javascript-diagram.html
and an simple angular application in the below link,
https://mindfusion.eu/Forum/YaBB.pl?num=1531413146/1
May I know how to find/download more angular sample diagram?
Thanks & Regards,
Kannan
Reply #3 - Jan 30th, 2019 at 2:21pm
We don't have other angular examples, except last post here -
https://mindfusion.eu/Forum/YaBB.pl?num=1548835998/1#1
Otherwise there are TypeScript DOM-API based ones available in the distribution's Samples folder.
Kannan Thirumal
Senior Member
Reply #4 - Feb 5th, 2019 at 12:59pm
I'm using typescript and got the diagram object as below,
import Diagram = MindFusion.Diagramming.Diagram;
this.diagram = Diagram.create(document.querySelector('#diagram'));
May I know how to get the canvas object which can be used to convert to image using the below code,
var img = canvas.toDataURL("image/png", "");
Kannan
Slavcho wrote on Jan 18th, 2019 at 9:31am:
f
Lyubo
MindFusion team
Reply #5 - Feb 5th, 2019 at 1:13pm
The argument passed to the Diagram.create method is actually the Canvas DOM element. You can get it with document.querySelector('#cavasElementId').
Lyubo
Kannan Thirumal
Senior Member
Reply #6 - Feb 8th, 2019 at 6:21am
Ok. Thanks ! I could see the js diagram documentation in the below link,
https://www.mindfusion.eu/onlinehelp/jsdiagram/index.htm
Do we have similar documentation for typescript?
Kannan
Slavcho wrote on Jan 30th, 2019 at 2:21pm:
« Last Edit: Feb 8th, 2019 at 8:35am by Kannan Thirumal »
Lyubo
MindFusion team
Reply #7 - Feb 8th, 2019 at 10:20am
The documentation is only in JavaScript.
We provide definitions files - jsdiag.d.ts and jscommon.d.ts - a samples project with different examples, written in TypeScript (in the .\Samples\TypeScript folder), plus an Angular example (in the .\Samples\Angular folder).
These are available in the JavaScript Diagram Library package, available here: https://mindfusion.eu/javascript-diagram.html.
Lyubo
Kannan Thirumal
Senior Member
Reply #8 - Mar 7th, 2019 at 2:26pm
I want to export the diagram through code like this,
var canvas = document.createElement("canvas");
let diagram = new Diagram(canvas);
let factory = <any>diagram.getFactory();
let node1 = factory.createShapeNode(10, 10, 20, 10);
let node2 = factory.createShapeNode(10, 50, 20, 10);
let node3 = factory.createShapeNode(50, 100, 20, 10);
factory.createDiagramLink(node1, node2);
const link = document.createElement('a');
link.download = 'Diagram-html.png';
link.href = img;
link.click();
But this doesn't seems working. Any idea why? Thank you !
Kannan
Lyubo
MindFusion team
Reply #9 - Mar 7th, 2019 at 3:06pm
The diagram's CANVAS element, should be nested in a parent DIV container and before exporting the image data, you'll need to call the repaint method manually. In addition to that, you need to call the Diagram.create initializer and not the diagram's constructor directly.
The following changes to your code, produce the expected results in my test:
Code (Javascript)
var canvasParent = document.createElement("div");
canvasParent.appendChild(canvas);
let diagram = Diagram.create(canvas);
diagram.repaint();
(<any>link).download = 'Diagram-html.png';
link.href = img;
link.click();
Lyubo
Kannan Thirumal
Senior Member
Reply #10 - Mar 12th, 2019 at 10:21am
Hi Lyubo,
That works. Thanks ! But the diagram having composite nodes are not working. Below is sample code,
let factory = <any>diagram.getFactory() as Factory;
var node = new this.OrgChartNode2();
node.setMainImage("./../../../../Main.png");
node.setFirstImage("./../../../../One.png");
node.setSecondImage("./../../../../Two.png");
node.setThirdImage("./../../../../Three.png");
node.setFourthImage("./../../../../Four.png");
node.setNoOfElementsText("8");
diagram.addItem(node);
diagram.repaint();
link.href = img;
link.click();
OrgChartNode2 = CompositeNode.classFromTemplate("OrgChartNode2",
component: "GridPanel",
rowDefinitions: ["*"],
columnDefinitions: ["22"],
children:
rowDefinitions: ["18", "5"],
columnDefinitions: ["18", "5"],
children:
gridColumn: 0,
component: "Image",
autoProperty: true,
margin: "3",
imageAlign: "TopLeft"
gridColumn: 0,
component: "Image",
autoProperty: true,
margin: "3, 3, 0, 0",
gridColumn: 1,
component: "Image",
autoProperty: true,
margin: "3, 3, -50, 5",
imageAlign: "TopRight"
gridColumn: 1,
component: "Image",
autoProperty: true,
margin: "3, 30, -50, 3",
imageAlign: "TopRight",
width: "3"
gridColumn: 1,
component: "Image",
autoProperty: true,
margin: "3, 50, -50, 3",
imageAlign: "BottomRight",
width: "3"
gridColumn: 0,
component: "Text",
autoProperty: true,
text: "title",
margin: "3, 40, 0, 0",
font: "Verdana 12px",
textAlign: "BottomLeft"
Images are not exported. Only text is exported. May I know why this didn't work for me?
Kannan
Lyubo
MindFusion team
Reply #11 - Mar 13th, 2019 at 6:02am
Most likely when you copy the canvas to the exported image, the node children images are not loaded. Try calling your export from a timeout:
Code (Javascript)
setTimeout(function ()
    link.href = img;
    link.click();
}, 100);
Lyubo
Kannan Thirumal
Senior Member
Reply #12 - Mar 13th, 2019 at 7:14am
Hi Lyubo,
Yes, this works. Thank you !
I noticed the same when the same diagram is rendered in the browser also. ie. the images are loading slowly. Any idea why this happens?
Kannan
Lyubo
MindFusion team
Reply #13 - Mar 13th, 2019 at 7:45am
DOM Image elements are loaded asynchronously, that's why the delay is needed. A more robust approach will be to handle the images' load event and do the repaint and export only after the last image has been loaded. In your case, something like:
Code (Javascript)
var loadedImages = 0, numberOfImages = 5;
function onImageLoad()
    loadedImages++;
    if (loadedImages >= diagram.getNodes().length * numberOfImages) // all images are loaded, export now
        diagram.repaint();
        var link = document.createElement('a');
        link.href = img;
        link.click();
//after nodes are created, attach the handler
for (var i = 0; i < diagram.getNodes().length; i++)
	var item = diagram.getNodes()[i];
	item.getComponent("MainImage").image.addEventListener("load", onImageLoad.bind(item));
	item.getComponent("FirstImage").image.addEventListener("load", onImageLoad.bind(item));
	item.getComponent("SecondImage").image.addEventListener("load", onImageLoad.bind(item));
	item.getComponent("ThirdImage").image.addEventListener("load", onImageLoad.bind(item));
	item.getComponent("FourthImage").image.addEventListener("load", onImageLoad.bind(item));
Lyubo
Kannan Thirumal
Senior Member
Reply #14 - Mar 21st, 2019 at 6:31am
Hi Lyubo,
     Thank you. May I know how to print the diagram?
Kannan
