Normal Topic Custom style for one key (Read 1905 times)
MisteryGuy_07
Feb 1st, 2019 at 4:39pm
Is there any way to set a custom font on a key? I probably will do it with a DataTrigger but I wonder if there's a better way Smiley
Re: Custom style for one key
Reply #1 - Feb 4th, 2019 at 11:14am
If you mean for just one specific key instance, you'll have to add a data trigger indeed, something like <DataTrigger Binding="{Binding LowerCase}" Value="a">. Inside the trigger try adding FontFamily property setter for the rootGrid shown at https://mindfusion.eu/Forum/YaBB.pl?num=1478183033/1#1 , or if it doesn't work on the grid, set a name for the TextBlock element which you could then use as a TargetName.
