Normal Topic Losing focus with unicode key (Read 2427 times)
MisteryGuy_07
Feb 7th, 2019 at 5:13pm
There is a problem where I can't input unicode keys. When I press an unicode key the target window loses focus and no input is send to the target window. Keyboard works with any other regular or special keys. Is this a known bug or something I'm doing wrong with my coding?
MisteryGuy_07
Re: Losing focus with unicode key
Reply #1 - Feb 7th, 2019 at 5:25pm
Or is there a simpler solution? I want an @ exclusive key
Reply #2 - Feb 8th, 2019 at 10:48am
Is this in stand-alone mode sending to external process, or it's your own application's window? Please post the keyboard's properties you are using. Another option you could try for a @ symbol is RegularKey instance with Content set to a "@" string.
