Normal Topic Cell click or cell double click events for table node (Read 1394 times)
Shafi
May 10th, 2019 at 12:56pm
Is there a cell click/doubleclick event for table node?
Re: Cell click or cell double click events for table node
Reply #1 - May 13th, 2019 at 7:39am
Call cellFromPoint method from node double / click event handlers -
if (node.cellFromPoint)
    var cellInfo = node.cellFromPoint(eventArgs.mousePosition);
    if (cellInfo)
        // cellInfo contains { cell..., cellRect..., column..., row...} fields
Shafi
Reply #2 - May 14th, 2019 at 11:33am
How can I select a cell and not the node? Currently on click/selection, the complete node is selected.
Reply #3 - May 14th, 2019 at 11:37am
There's no selection of individual cells supported, as selection state mostly pertains to subsequent move / resize operations. You could keep a reference to the cell object as a field of the TableNode if you need to access it later, and set cell's Brush to indicate selection state to users.
