MindFusion
  We have released initial version of MindFusion.JavaScript pack. It includes chart, diagram, calendar, map, virtual keyboard, gauge and UI components. Here are more details and live demo for anyone interested.
  HomeHelpSearchLoginRegister
What is the file name format for layouts in the LayoutsFolder
Read 76 times
ToddK   Offline
May 15th, 2019 at 8:42pm
I saw elsewhere that  "the control will try to load a layout file with culture's locale id in its name from LayoutsFolder".
Can I get more specifics on the layout filename?
is it just en-us.xml
Or can you have somename_en-us.xml?
Oh, when the keyboard is in custom mode, does changing inputLocale still change the OS input culture?
I saw in the Layouts sample code, the custom layout was an embedded resource. Can we use embedded key images, and if so, how?
Slavcho   Offline
Gender: male
Re: What is the file name format for layouts in the LayoutsFolder
Reply #1 - May 16th, 2019 at 12:16pm
The name should contain Windows' LCID for that locale. You will get it added automatically to the file name by Keyboard Creator tool when you save a custom layout (LCID for the locale selected in property pane on the right).
InputLocale is something the keyboard sets automatically in response to system's language change. If you want to set the input language of a process that embeds the keyboard, set InputLanguageManager.Current.CurrentInputLanguage. If you use the keyboard in standalone mode and need to set language of external applications, you should be able to by sending WM_INPUTLANGCHANGEREQUEST Windows message to the application's main window like PostMessage(hWnd, WM_INPUTLANGCHANGEREQUEST, INPUTLANGCHANGE_FORWARD, MYLOCALE);
The image names stored with layouts can only be loaded from external files. Maybe you could use embedded images by mapping key codes to embedded image resources through key's data templates and some binding converters.
