MindFusion
  We have released initial version of MindFusion.JavaScript pack. It includes chart, diagram, calendar, map, virtual keyboard, gauge and UI components. Here are more details and live demo for anyone interested.
  HomeHelpSearchLoginRegister
Drag diagram link by name
Read 449 times
lexeranddn   Offline
May 22nd, 2019 at 1:10pm
Is it possible to drag diagramlink by name?
Slavcho   Offline
Gender: male
Re: Drag diagram link by name
Reply #1 - May 22nd, 2019 at 2:35pm
Do you mean by grabbing its Text or LinkLabels? And then what would you expect  the drag operation to do?
lexeranddn   Offline
Reply #2 - May 22nd, 2019 at 2:54pm
Slavcho wrote on May 22nd, 2019 at 2:35pm:
By Text, drag operation.
Slavcho   Offline
Gender: male
Reply #3 - May 23rd, 2019 at 9:39am
Changing text's position by dragging it is not supported if that's what you mean. Try using a ShapeNode attached to the DiagramLink (with AttachTo method) to achieve that. Set Transparent property of such nodes to hide their geometry and leave only their Text visible.
lexeranddn   Offline
Reply #4 - May 23rd, 2019 at 11:02am
Slavcho wrote on May 23rd, 2019 at 9:39am:
Thanks Slavcho, but I mean dragging diagramLink by its Text, not only dragging Text itself.
Slavcho   Offline
Gender: male
Reply #5 - May 23rd, 2019 at 2:32pm
But what should the drag operation do? Like move the whole link, the segment where text is located, or nearest control point?
lexeranddn   Offline
Reply #6 - May 23rd, 2019 at 3:32pm
Slavcho wrote on May 23rd, 2019 at 2:32pm:
The whole link.
Regards
Slavcho   Offline
Gender: male
Reply #7 - May 24th, 2019 at 8:44am
You can find code for moving the whole link here -
https://mindfusion.eu/Forum/YaBB.pl?num=1548142738/1#1
I can't see any public API to detect where link.Text is located. If you use a LinkLabel instance instead of Text, you could then call LinkLabel.GetEditRect to find the label's position. Other than that, maybe use WPF's VisualTreeHelper to find if there's a GlyphRunDrawing near the mouse position.
lexeranddn   Offline
Reply #8 - May 27th, 2019 at 2:14pm
Slavcho wrote on May 24th, 2019 at 8:44am:
Thanks, Slavcho!
