Normal Topic Semi Transparent Node ! (Read 1210 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Jul 1st, 2019 at 2:01pm
     May I know how to make a shape node semi transparent like the one attached?
Kannan
Lyubo
MindFusion team
Re: Semi Transparent Node !
Reply #1 - Jul 2nd, 2019 at 5:30am
You can set a RGBA color value to the node's brush with opacity lower than 1.0 for the alpha channel. You may also need to disable the node's shadow or it will show below the node:
Code (Javascript)
node.setBrush("rgba(220, 220, 255, 0.6)");
node.setShadowColor("Transparent");
Lyubo
Kannan Thirumal
Senior Member
Reply #2 - Jul 2nd, 2019 at 8:00am
It works ! Thank you Lyubo !
Previously I tried setBrush with rgba but missed setShadowColor to Transparent.
If setShadowColor is NOT set to Transparent, then the node itself is NOT transparent.
« Last Edit: Jul 2nd, 2019 at 9:12am by Kannan Thirumal »
