Normal Topic Edit Mode on the container node (Read 825 times)
Shafi
Jul 12th, 2019 at 2:07pm
How to find that the Container node is currently in edit mode?
Re: Edit Mode on the container node
Reply #1 - Jul 15th, 2019 at 8:42am
Handle enterInplaceEditMode event and check if eventArgs.item is a container, or save the reference if you need to check later - will be valid until leaveInplaceEditMode is called.
