Hot Topic (More than 10 Replies) Overlapping Routed Links (Read 5409 times)
Kannan Thirumal
Senior Member
I Love Mind Fusion Diagram
Jul 30th, 2019 at 7:24am
I've few nodes (vertical) connected with routed links. But they are overlapping.
Here is the code,
private createVerticalNodes() {
var node1 = this.diagram.getFactory().createShapeNode(new Rect(500, 0, 200, 50));
node1.setText("node 1");
node1.setBrush("white");
node1.setTextAlignment(Alignment.Center);
node1.setTextPadding(new Thickness(10, 10, 10, 10));
node1.setFont(new Font("Meiryo UI", 15, true, false, false));
node1.resizeToFitText(common.Diagramming.FitSize.KeepWidth);
this.diagram.addItem(node1);
var node2 = this.diagram.getFactory().createShapeNode(new Rect(500, 200, 200, 50));
node2.setText("node 2");
node2.setBrush("white");
node2.setTextAlignment(Alignment.Center);
node2.setTextPadding(new Thickness(10, 10, 10, 10));
node2.setFont(new Font("Meiryo UI", 15, true, false, false));
node2.resizeToFitText(common.Diagramming.FitSize.KeepWidth);
this.diagram.addItem(node2);
var node3 = this.diagram.getFactory().createShapeNode(new Rect(500, 400, 200, 50));
node3.setText("node 3");
node3.setBrush("white");
node3.setTextAlignment(Alignment.Center);
node3.setTextPadding(new Thickness(10, 10, 10, 10));
node3.setFont(new Font("Meiryo UI", 15, true, false, false));
node3.resizeToFitText(common.Diagramming.FitSize.KeepWidth);
this.diagram.addItem(node3);
var node4 = this.diagram.getFactory().createShapeNode(new Rect(500, 600, 200, 50));
node4.setText("node 4");
node4.setBrush("white");
node4.setTextAlignment(Alignment.Center);
node4.setTextPadding(new Thickness(10, 10, 10, 10));
node4.setFont(new Font("Meiryo UI", 15, true, false, false));
node4.resizeToFitText(common.Diagramming.FitSize.KeepWidth);
this.diagram.addItem(node4);
var link1 = this.diagram.getFactory().createDiagramLink(node1, node2);
link1.setAutoRoute(true);
link1.setBrush("blue");
link1.setStroke("blue");
link1.setStrokeThickness(3);
link1.route();
var link2 = this.diagram.getFactory().createDiagramLink(node2, node3);
link2.setAutoRoute(true);
link2.setBrush("#82E0AA");
link2.setStroke("#82E0AA");
link2.setStrokeThickness(3);
link2.route();
var link3 = this.diagram.getFactory().createDiagramLink(node3, node4);
link3.setBrush("#7D3C98");
link3.setStroke("#7D3C98");
link3.setStrokeThickness(3);
link3.setAutoRoute(true);
link3.route();
var link4 = this.diagram.getFactory().createDiagramLink(node1, node4);
link4.setAutoRoute(true);
link4.setBrush("Orange");
link4.setStroke("Orange");
link4.setStrokeThickness(3);
link4.route();
this.diagram.repaint();
Attached the screen shots. Also uploaded the complete code in the below url,
https://drive.google.com/open?id=1K8t0uEg7LW9ZUZ-UJe0-EOaVfRetnkNm
May I know how to auto route these links properly without overlapping. Thanks !
Kannan
Lyubo
MindFusion team
Re: Overlapping Routed Links
Reply #1 - Jul 30th, 2019 at 11:02am
Instead of calling route() individually on every link, to avoid the overlapping call diagram.routeAllLinks() in the end.
Lyubo
Kannan Thirumal
Senior Member
Reply #2 - Jul 30th, 2019 at 11:31am
I tried that too, but still not working. Could you please check this code?
//link1.route();
//link2.route();
//link3.route();
//link4.route();
//this.diagram.repaint();
this.diagram.routeAllLinks();
Kannan
« Last Edit: Aug 1st, 2019 at 8:58am by Kannan Thirumal »
Kannan Thirumal
Senior Member
Reply #3 - Aug 7th, 2019 at 8:05am
     Did you had a chance to check this? Thank you !
Kannan
Reply #4 - Aug 8th, 2019 at 6:25am
Try this code, with and without distributeLinks -
//for (var node of diagram.nodes)
//	distributeLinks(node);
diagram.linkRouter = new MindFusion.Diagramming.GridRouter(diagram);
diagram.routeMargin = 20;
function distributeLinks(node)
	var rect = node.getBounds();
	var bottomLinks = collectLinks(node,
		p => Math.abs(p.y - rect.bottom()) < 1);
	distributeX(node, bottomLinks);
	var topLinks = collectLinks(node,
		p => Math.abs(p.y - rect.top()) < 1);
	distributeX(node, topLinks);
Get rest of the functions from this post -
https://mindfusion.eu/Forum/YaBB.pl?num=1547140103/1#1
If using distributeLinks(), you might modify it to keep the first of node's links always centered and pull away only the rest of them.
Kannan Thirumal
Senior Member
Reply #5 - Nov 12th, 2019 at 12:15pm
I tried the same. Please check the attached outcome and the expected behavior.
     Please download the sample code in this url,
     https://drive.google.com/open?id=14eZ5sENigCqU8qxIP_QDYhOCt7F_dGsg
Kannan
Kannan Thirumal
Senior Member
Reply #6 - Nov 15th, 2019 at 3:48am
The expected behavior is how it is happening in silverlight/wpf mind fusion diagram by just routing and without any other extra logic. We need the same in html too. May I know how?
Kannan
Kannan Thirumal wrote on Nov 12th, 2019 at 12:15pm:
Kannan
Reply #7 - Nov 15th, 2019 at 5:23am
It looks like you call distribute after routeAllLinks, and not before it as the sample code shows. We'll have in mind porting the WPF router to JavaScript diagram for next release.
Kannan Thirumal
Senior Member
Reply #8 - Nov 15th, 2019 at 8:26am
Thank you. May I know when I can expect the next release?
Reply #9 - Feb 5th, 2020 at 12:27pm
We are preparing some improvements in default Router for upcoming release, check if this build works better for you -
https://mindfusion.eu/_beta/jsdiag34.zip
Please also set a larger routeMargin value to match your smaller measure units -
diagram.setRouteMargin(100);
Kannan Thirumal
Senior Member
Reply #10 - Apr 27th, 2020 at 12:08pm
Hi Slavcho,
May I know whether this is ported and available in the latest diagram release?
Kannan
Slavcho wrote on Nov 15th, 2019 at 5:23am:
Reply #11 - Apr 27th, 2020 at 6:16pm
We have improved the standard router as shown in previous post. Have you tried that version?
